Import of responsibles and ressources from a cvs file
I’m trying to import csv file out of an excel file with all tasks, dates, ressources and comments.
It works globally fine. Tasks and ressources are imported, if you change semicolon to comma in the resulting cvs file, but the values in field responsible are not imported and values of ressources not all the time.
I verified lots of things like caracters, text length, names,…without success until now.
Thank you for your assistance.
Kindly
Denis
Please share a file that you’re having issues with and provide information about the expected result.
You can configure a column delimiter in Edit > Settings> Spreadsheets
Thank you for your quick answer.
Attached the file
Kind regards
Denis
import 22-04-2025 v5.csv (39,9 Ko)
Expected is to have import of responsible and ressources in Ganttproject with all other datas.
Kind regards.
Denis
