I messed around with the import from csv file and faced some particular situation : I’ve got two csv file with the exact same content, one is able to be imported in ganttproject but not the other one
Not Working.csv (162 Bytes) Working.csv (165 Bytes)
I did all the tricks(export from ganttproject, check the csv data structure, bla bla bla) I just wanted to lean the csv file as much as possible until I faced this issue. Any clues ?
PS : The column names are in french since this is the version installed on my PC ; those are the stock column names in the csv file when I export from ganttproject. I don’t know if the import module is language sensitive.
Thank you
