Tried to run with JRE v17, launched successfully but some errors on path, with flag “–release 11”.
(part of .bat file in Win10)
SET “JAVA_COMMAND=%JAVA_HOME%\bin\java.exe”
IF “%JAVA_HOME%”=="" SET JAVA_COMMAND=java
SET LOCAL_CLASSPATH=%GP_HOME%\eclipsito.jar;%GP_HOME%
SET JVM_ARGS=-Xmx2g -ea -Dsun.java2d.d3d=false
SET “ECLIPSITO_ARGS= - -release 11 --verbosity 1 --version-dirs plugins;~/.ganttproject.d/updates --app net.sourceforge.ganttproject.GanttProject”
:SET CONFIGURATION_FILE=ganttproject-eclipsito-config.xml
SET BOOT_CLASS=com.bardsoftware.eclipsito.Launch
java -classpath “%CLASSPATH%;%LOCAL_CLASSPATH%” %JVM_ARGS% %BOOT_CLASS% %ECLIPSITO_ARGS% -log true %1 %2 %3 %4 %5 %6
if %ERRORLEVEL% EQU 9009 goto ERROR_NO_JAVA
goto END
Is that possible or it is just needed to do something else with the GP v3.1 build to run?
Thank you!
