It just frozen on splash screen like this:
Re-install totally (got 3.3.3240) solved the problem.
~/ganttproject.log
GanttProject 3.3.3290
java.class.path: /Applications/GanttProject.app/Contents/app:/Applications/GanttProject.app/Contents/app/eclipsito.jar:/Applications/GanttProject.app/Contents/app/lib/slf4j-api-2.0.3.jar:/Applications/GanttProject.app/Contents/app/lib/slf4j-jdk14-2.0.3.jar
java.home: /Applications/GanttProject.app/Contents/runtime/Contents/Home
java.ext.dirs: null
java.io.tmpdir: /var/folders/fq/sphm_1v56yl_c5146s0qhg340000gn/T/
java.runtime.version: 17.0.5+8-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 17.0.5+8-LTS
os.arch: aarch64
os.name: Mac OS X
os.version: 13.3.1
sun.java.command: com.bardsoftware.eclipsito.Launch --verbosity 4 --version-dirs plugins:~/.ganttproject.d/updates --app net.sourceforge.ganttproject.GanttProject
user.country: CN
user.dir: /Applications/GanttProject.app/Contents/app
user.home: ~
user.language: en
user.timezone: Asia/Shanghai[2023-06-12 01:53:21] [INFO][net.sourceforge.ganttproject] Starting RSS check…
[2023-06-12 01:53:21] [INFO][net.sourceforge.ganttproject] Deleting old auto-save files
[2023-06-12 01:53:27] [INFO][Eclipsito] Will download 16251545 bytes and save as file /var/folders/fq/sphm_1v56yl_c5146s0qhg340000gn/T/ganttproject-update6829761130687433900zip
[2023-06-12 01:53:31] [INFO][net.sourceforge.ganttproject] [GanttOptions] save(): finished!!
[2023-06-12 01:54:37] [INFO][org.apache.http.impl.client.DefaultHttpClient] I/O exception (java.net.NoRouteToHostException) caught when connecting to {s}->https://ganttproject-frontpage.blogspot.com:443: No route to host
[2023-06-12 01:54:37] [INFO][org.apache.http.impl.client.DefaultHttpClient] Retrying connect to {s}->https://ganttproject-frontpage.blogspot.com:443
[2023-06-12 01:54:55] [INFO][net.sourceforge.ganttproject] [GanttOptions] save(): finished!!
The log was written to null
Tried command line:
JAVA_HOME=/Applications/GanttProject.app/Contents/runtime/Contents/Home ./ganttproject
WARNING: package sun.awt.X11 not in java.desktop
Jun 12, 2023 10:05:36 AM com.bardsoftware.eclipsito.runtime.ModuleRuntime build
FINE: We will run with the following plugins:
Jun 12, 2023 10:05:36 AM com.bardsoftware.eclipsito.runtime.ModuleRuntime lambda$build$3
FINE: Plugin org.ganttproject.chart.pert-3.3.3290 at /Applications/GanttProject.app/Contents/app/plugins/base/org.ganttproject.chart.pert/plugin.xml
FINE: Plugin biz.ganttproject.impex.msproject2-3.3.3290 at /Applications/GanttProject.app/Contents/app/plugins/base/biz.ganttproject.impex.msproject2/plugin.xml
FINE: Plugin biz.ganttproject.app.localization-3.3.3290 at /Applications/GanttProject.app/Contents/app/plugins/base/biz.ganttproject.app.localization/plugin.xml
FINE: Plugin biz.ganttproject.impex.ical-3.3.3290 at /Applications/GanttProject.app/Contents/app/plugins/base/biz.ganttproject.impex.ical/plugin.xml
FINE: Plugin org.ganttproject.impex.htmlpdf-3.3.3290 at /Applications/GanttProject.app/Contents/app/plugins/base/org.ganttproject.impex.htmlpdf/plugin.xml
FINE: Plugin net.sourceforge.ganttproject-3.3.3293 at /Applications/GanttProject.app/Contents/app/plugins/update-3293/ganttproject/plugin.xml
FINE: Plugin biz.ganttproject.app.libs-3.3.3290 at /Applications/GanttProject.app/Contents/app/plugins/base/biz.ganttproject.app.libs/plugin.xml
FINE: Plugin biz.ganttproject.core-3.3.3290 at /Applications/GanttProject.app/Contents/app/plugins/base/biz.ganttproject.core/plugin.xml
Jun 12, 2023 10:05:36 AM com.bardsoftware.eclipsito.runtime.Runner run
FINE: Command line args: [-log, true, -log_file, /Users/pinxue/.ganttproject.d/logs/.ganttproject-20230612100536.log]
FINE: Launching application=net.sourceforge.ganttproject.GanttProject
