Margins when printing (was: Поля страницы при распечатывании напрямую из Проекта)
При распечатывании напрямую из Проекта созданного изображения поля большие. Расстояние верхнего края изображения очень большое, в результате часть диараммы переходит на следующий лист. Как уменьшить поля?
this is English-speaking forum and community. Please consider writing in English, so that texts were understandable to other people. Here is how you message is translated by Google Translate:
When printing the created image directly from the Project, the fields are large. The distance of the upper edge of the image is very large, as a result of which part of the diorama moves to the next sheet. How to reduce margins?
Indeed, it seems that print dialog on Windows does not add page setup automatically (it does on Linux). That’s one of the reasons why we recommend exporting chart to PNG image and using other tools (e.g. MS Paint or other standard image viewer) for printing.
