Buonasera vorrei sapere se si può’ modificare il report di esportazione in pdf.
Translation provided by GoogleTranslate:
Good evening I would like to know if you can edit the export report in pdf.
This is English speaking community. Please consider writing in English for better understanding.
I am not sure that I clearly understand what do you mean as “edit the report in PDF”. There are some tools to edit PDF, e.g. Adobe Acrobat. GanttProject is not a PDF editor.
Good evening dmitry, I apologize for not writing in English, my question was whether I can edit the report or other downloadable reports exist for the gantt project, there is only the Sortalava.
Thank you so much for your help.
PDF reports are currently coded in Java. You can theoretically change it, if you’re a software engineer, but that’s not trivial, sorry.
Thank you so much…
