I tried to run GanttProject natively with Zulu JDK on Apple silicon M1.
Hardware: Macbook Pro with M1 chip.
JDK: Zulu JDK (ARM64).
I download GanttProject 3.0 (zip fiel), unzipped it, and execute ‘./ganttproject.command’, no UI shows up but not exception.
Then I noticed there is a process running in the background, just the UI doesn’t show up.
Any idea of what happended?
BTW, the reason why I use Zulu JDK is that the performance running with the built-in JRE (with Rosetta) is horibly slow.
- Cliff
