Hi, I just uploaded a project to the cloud and worked on it. Now I want to open it in my local computer without internet connection, work on it and synchronize it with the cloud version when I go online again; how do I do that?
If you have offline copies of the cloud documents on your computer (it is switched on by default) then you just click “GanttProject Cloud” in the file dialog. It will detect that you are offline and will show you a list of available offline copies of your documents. They are local files on your disk and you can edit them and save them. When you go online, GanttProject will upload the offline copies, provided that the online copy has not changed while you have been offline.
