PDF export options
Export to PDF of my first Gantt chart gives “Untitled Gantt Project” as a title.
the file has a title.
Where do I change this "Untitled Gantt Project " to some meaningfull title?
thanks for your support
Open the project file in a text editor. In the first line there is a tag called “project name=”. Set this to your desired name. Save and close. Export again. The pdf should now have the correct name
The reply needs at least 20 characters, so thank you ver much😀.
