Print crops top and bottom lines
Print from gantt chart view has very small top and bottom margins that crops the content (half the “week” line and half of the bottom-most task). Content is otherwise OK. Using Win11, A4, print all pages.
Can you provide an example of how it looks? And how your print settings look like?
Hi Dmitry, I just use control P and follow the printer settings (expert user). I didn’t go with the PDF export (that’s a messy way).
It clips off the top line (week numbers) and 10% of the next line (ID, name, predecessor labels). It doesn’t matter if it’s one page or a complete project to print. Everything else prints properly. Normal working on the screen is perfect. Printing it borderless makes it worse (erases 90% of line 2).
I have resorted to screen-capturing sections and pasting them into Word.
Regards, John
Please provide something that visually illustrates the issue.
Also, there is a button “Export pages as ZIP” in the print preview dialog which creates a ZIP archive with images. Did you try using it and is the issue reproducible with them?
