Print/Export problem
I’m using the latest version 3.2.3221 and I noticed there is a bug when I print or export the file (in all the formats HTML, jpeg, pdf). The gray bar at the top is super-big as you can see in the image below.
I tried to remove the festivity calendar, to change the language e to restart many times the program but it does not change anything.
I think that you set a very tall image as the logo.
ooooopppssss, you’re right :frowning: Problem solved.
Thank you!
