Problème apparence impression
Bonjour,
Lorsque j’imprime un planning depuis un PDF dant l’apparence des lignes est pleines, l’apparence des ligne est avec des petits poids lorsque j’imprime.
Comment puis-je imprimer correctement
Le PDF
L’impression
Merci
We do not speak French, sorry. Your message translated with Google Translate is quoted below. Please consider using English for better understanding.
When I print a schedule from a PDF where the appearance of the lines is full, the appearance of the lines is with small weights when I print.
How can I print correctly
The PDF
I am not sure that I understand the question, and what is “the full appearance of the lines” and “small weights”.
PDF export works as expected for me and creates the task bar fully filled with colors.
L’apparence du PDF sur l’écran du PC est OK mais lorsque j’imprime j’ai ça.
Please share the project file and the result of the PDF export.
DELTA STER sale planning.gan (14,5 Ko)
DELTA STER sale planning.pdf (164,8 Ko)
The chart from your PDF file looks just fine
