Today, first version 2.8.11didn’t start anymore. Next, I downloaded the Version 3. Here just the splash screen launches, but the program does not start further. Tried deinstall and install both version several times, but without success any issues are known?
You can try removing the options file. Chances are it went corrupted. The options file is named .ganttproject and it is located in your home folder. Note the leading dot in the file name. It might be hidden in some file browsers.
Hi Dmitry, Thank you a lot for the fast response. Yes indeed, deleting the options file .ganttproject successfully solved the problem. Thank you again, Joerg
