Resource availability impact on task duration
I’d like to know how to make GanttProject modify the duration (or end date) of a task depending on the (in)availability of a ressource allocated to the task.
Thank you
Effort-driven scheduling is not supported, sorry.
Thank you for the response.
Do you think it is a feature worth the implementation ?
Sure, but it is a non-trivial feature both from technical and UX perspectives.
There is an existing issue in the bug tracker:
OK, I understand. I’ll subscribe to the GitHub bugtracker thread to keep in touch.
