I am trying out Gantproject. It is not starting.
OS: Windows 10 Pro, 32 bit
I tried the batch file. At first I got the message that the java.exe does not match my system.
I downloaded the 32 Java Runtime from liberica and adjusted the JAVA_HOME environment variable in the batch file. The error message is gone. But nothing happens, ie. the program starts but there is no new window, as I would expect.
The command line is
“D:\Programme\GanttProject-3.1\runtime\bin\java.exe” -classpath “;.\eclipsito.jar;.” -Xmx512m -ea -Dsun.java2d.d3d=false com.bardsoftware.eclipsito.Launch --verbosity 1 --version-dirs plugins;~/.ganttproject.d/updates --app net.sourceforge.ganttproject.GanttProject -log true
Where can I find the log file? C:\Users%USERNAME% ?? There ist not ganttproject.log
Regards
Rüdiger
