When I export to pdf, I always loose my settings: Date, page size. Is there any change to save these settings?
thank you
thank you
Can you please clarify what settings do you mean?
Hi Dmitry,
Thank you for your reply.
As I wrote, I meant page size and a date range.
For these two parameters, for examples, I have to set all the time I use export to pdf. For the date range it is very annoying.
Cheers,
Dario
Did you mean those which are on PDF export page?
Thanks for reminding. This is addressed in this ticket: Save the export PDF setup · Issue #737 · bardsoftware/ganttproject · GitHub
yes. I opened your link, but I see only the question and not the solution. Sorry
It means that there is no solution at the moment.
