When I save my projects I can see the file saved in the Home user folder. It would be better if I could save my projects in a folder (named “Gantt projects” e.g.) wherever I want, but I couldn’t find any option in the settings window and nowhere else.
Is it possible to set a different default folder?
GanttProject remembers the last used folder, so if you save one project in “Gantt projects”, it will become the default for file save/open operations.
I can’t save projects in any other folder than the Home user folder. I always receive the error “Access denied”. Is it only possible to save to a folder within the user folder?
GanttProject does not enforce any restrictions, it is operating system and file system which may reject writes to some folders because of user permissions.
If you’re not an administrator on the computer where you run GanttProject then yes, chances are that you do not have permissions to write anywhere but your home folder.
Can you attach the log file contents? Help > View log
Thanks for your response. I am the administrator on this PC.
Here’s the log file content:
C:\Users\Nina\ganttproject.log
GanttProject 2.8.7 Pilsen (build 2256)
java.class.path: eclipsito.jar;C:\Program Files\GanttProject-2.8
java.home: C:\Program Files\Java\jre1.8.0_171
java.ext.dirs: C:\Program Files\Java\jre1.8.0_171\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.io.tmpdir: C:\Users\Nina\AppData\Local\Temp
java.runtime.version: 1.8.0_171-b11
java.vm.name: Java HotSpot™ Client VM
java.vm.version: 25.171-b11
os.arch: x86
os.name: Windows 10
os.version: 10.0
sun.java.command: org.bardsoftware.eclipsito.Boot ganttproject-eclipsito-config.xml -log true
user.country: GB
user.dir: C:\Program Files\GanttProject-2.8
user.home: C:\Users\Nina
user.language: en
user.timezone: Europe/Berlin
Jul 03, 2018 11:37:47 AM net.sourceforge.ganttproject.GPLogger log
INFO: Options file:C:\Users\Nina.ganttproject
Jul 03, 2018 11:37:48 AM net.sourceforge.ganttproject.GPLogger log
Creating main frame…
- loading look’n’feels
no editor for column=2 class=interface javax.swing.Icon - loading options
- creating menus…
- creating views…
- changing language …
Jul 03, 2018 11:37:49 AM net.sourceforge.ganttproject.GPLogger log
INFO: Bounds stored in the options: java.awt.Rectangle[x=-8,y=-8,width=1936,height=1056] - finalizing…
Main frame created
INFO: Bounds after setVisible: java.awt.Rectangle[x=-8,y=-8,width=1936,height=1056]
INFO: Starting RSS check…
Splash closed
Resizing window…
Jul 03, 2018 11:37:50 AM net.sourceforge.ganttproject.GPLogger log
INFO: Bounds after opening: java.awt.Rectangle[x=-8,y=-8,width=1936,height=1056]
Jul 03, 2018 11:37:52 AM net.sourceforge.ganttproject.GPLogger log
INFO: RSS check finished
Jul 03, 2018 11:37:57 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Jul 03, 2018 11:37:57 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=C:\Program Files\Java\jre1.8.0_171/lib/fonts
Jul 03, 2018 11:38:08 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=/C:/Program Files/GanttProject-2.8/plugins-2.8.7/org.ganttproject.impex.htmlpdf/resource/fonts
Jul 03, 2018 11:38:08 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Jul 03, 2018 11:39:17 AM net.sourceforge.ganttproject.GPLogger logToLogger
WARNING: C:\Users\Nina\Desktop\GanttProject\testproject2.gan (Access is denied)
java.io.FileNotFoundException: C:\Users\Nina\Desktop\GanttProject\testproject2.gan (Access is denied)
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(Unknown Source)
at java.io.FileOutputStream.(Unknown Source)
at net.sourceforge.ganttproject.document.FileDocument$1.(FileDocument.java:108)
at net.sourceforge.ganttproject.document.FileDocument.getOutputStream(FileDocument.java:108)
at net.sourceforge.ganttproject.document.ProxyDocument.getOutputStream(ProxyDocument.java:132)
at net.sourceforge.ganttproject.document.ProxyDocument.write(ProxyDocument.java:198)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.saveProject(ProjectUIFacadeImpl.java:137)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.saveProjectAs(ProjectUIFacadeImpl.java:179)
at net.sourceforge.ganttproject.GanttProject.saveAsProject(GanttProject.java:755)
at net.sourceforge.ganttproject.action.project.SaveProjectAsAction.actionPerformed(SaveProjectAsAction.java:44)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Do you have this folder on your computer?
Yes I do, the path is correct
And can you save files into that folder with other programs (e.g. Notepad) ?
Yes, I can save files into that folder with any program I’ve tried so far (Notepad, Notepad++, Word, Acrobat)
I found the problem! My Antivirus was blocking GanttProject. Now that I’ve unblocked it I can save to the folder
Wow, thanks for sharing the solution!
