Hi, I try to change the width of the last column, what is not possible.
Here in my example the column “Dauer”
The other columns the width is changeable by moving the double arrow between the columns.
What goes wrong?
regards
Alhard
What goes wrong?
regards
Alhard
I don’t understand the question. Your column “Dauer” is the widest on the screenshot. How did you manage to make it that wide if you can’t change its width?
Use the LEFT border to resize the width; the one between Dauer and Kosten
Thanks, I will respond next week
Thanks, Manuel
I will continue testing next week.
Gruß
Alhard
— Original Nachricht —
a short info today:
this line (see mouse pointer) I can NOT move !
this line I CAN move !
… more on Monday
thanks
It works as designed.
