In this screen shot you can see that GP omitted percent of resource totals here and there. In “Manufacturing Engineer” totals and in “Technical Engineer” totals, sometimes you see the percent utilized, sometimes not. Often if it’s over 100 it does not show.
When a resource is loaded 100% GP doesn’t show the value, but anything 0-99% or 101% upwards it will display the value for it… unless there isn’t enough room to display the text, in which case you will have to zoom in so that your task bar is long enough for it to contain the text relating to the percentage loading.
Note that this is also caused by some of your task bars being broken because they cross a weekend.
Hope that helps.
