I think that there is a problem between links with main tasts. I created a strong link between two main tasks (both with subtasks) as it is shown below:
Then I shortened subtast “zadanie_8” and unfortunately second main tast have not moved as you can see:
“Refresh” did not solved the problem.
Should I change some setting? Any advice?
Thanks!
