hello
for some reason in the gant chart , the tasks are appearing on the right pane and the graph appears on the left pane (left side).
how I can swap it back to have the tasks on the left and the graph on the rights.
S.Neeman
hello
S.Neeman
Can you post a screenshot?
It is Hebrew, isn’t it? In Right-to-Left locales user interface is shown right-to-left as well. Choose “English” language in the application settings to get back to left-to-right (and English in the user interface).
I see under EDIT / SETTING / APPLICATION UI the possibility to change languages.
from your message I understand that there are 2 places to change the language.
I found under the application user interface.
There is just one. I meant that by choosing English you will switch to left-to-right interface and to English translation.
Thanks you very much for your help.
I had to quit the application and when logged in back it swapped the panes.
