I have just updated Gantt Project to Version 3.3.3309 and the notes do not show on Gantt view.
However, if you check Task Properties, The notes are still there.
Is there a way to get them back as a Note Icon on the right of the Gantt view?
Thanks,
VQ
In GanttProject 3.3 the notes icon was moved to the table view, as requested in this issue:
It should be shown by default, however, if it is not, you can switch it on in the Column Manager dialog (click on the cog icon above the task table).
Wonderful I found it. Thanks a lot Dmitry. It is a most appropriate place for the icon…
Hello. I found the way to show the notes icon , but unfornutaley, this icon do not appear on the export pdf for example ? Is there a solution ?
best rgds
David
I have filed a bug report: Show notes icon in PDF export · Issue #2660 · bardsoftware/ganttproject · GitHub
Thanks for reporting!
I was also wondering where they were…
I noticed the preview has a timeout, so it disappear after a few seconds.
Would it be possible to leave it on, as long as the cursor is on it?
I write long notes…
