Hi, the export pdf option is not respecting the files row order.
Neither is the HTML export for that matter.
And the Title on both is not pulling the file name it is just showing the title as āUntitled Gantt Projectā
ok, I see the title is not coming from the file name but from the project settingsā¦
Are your tasks ordered by begin date (or any other field) in the table?
not sure what you mean. I selected the column heading to order the data?
Yes, did you order the tasks? Export functions take the tasks in their ādocument orderā, that is, in the order which is set manually by entering tasks or by explicit reordering with arrows. The order which is set by the column ordering is ignored by the export functions.
okā¦is that something to put on a wish list. seems onerous if you want to export by Begin date and then export by end dateā¦if you have to manually reorder items each time that would suck.
