Template for Repetitive Projects
Is it possible to create a template for repetitive projects? For example if I create a schedule for doing a property renovation, can I then save it as a template for use during subsequent renovation projects at differing dates. Thanks for your advice.
Create a project with the template data and save it somewhere e.g. in “GanttProject Templates” folder. When you need to create a new project from template, open this saved project and use “Save As” to save it in a new file.
If you need to move the project start date, use Project > Properties > Calendar > Move project start date
