I downloaded ganttproject today for a test and get this error right away when starting the application the first time and after that with each first “new project” click, but not on subseqental “new project” clicks.
My System is a MacOS 12.2.1 on M1
I have set Times new Roman as App and chart Font but that did not help .
What can i do?
/Users/<myuser>/ganttproject.log
GanttProject 3.2.3210
java.class.path: /Applications/GanttProject.app/Contents/app:/Applications/GanttProject.app/Contents/app/eclipsito.jar
java.home: /Applications/GanttProject.app/Contents/runtime/Contents/Home
java.ext.dirs: null
java.io.tmpdir: /var/folders/sf/yfrzcwy91jz9m0cc0y82g_k00000gn/T/
java.runtime.version: 11.0.13+8-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 11.0.13+8-LTS
os.arch: x86_64
os.name: Mac OS X
os.version: 12.2.1
sun.java.command: com.bardsoftware.eclipsito.Launch --verbosity 4 --version-dirs plugins:~/.ganttproject.d/updates --app net.sourceforge.ganttproject.GanttProject
user.country: <myCountry>
user.dir: /Applications/GanttProject.app/Contents/app
user.home: /Users/<myuser>
user.language: <myLanguage>
user.timezone: Europe/<myTZ>
Warning: the fonts "Times" and "Times" are not available for the Java logical font "Serif", which may have unexpected appearance or behavior. Re-enable the "Times" font to remove this warning.
Feb. 27, 2022 4:53:34 VORM. biz.ganttproject.LoggerImpl debug
FEIN: Creating main frame...
FEIN: 1. loading look'n'feels
FEIN: 2. loading options
Feb 27, 2022 4:53:35 AM biz.ganttproject.LoggerImpl debug
FINE: 3. creating menus...
FINE: 4. creating views...
Feb 27, 2022 4:53:36 AM biz.ganttproject.LoggerImpl debug
FINE: 5. calculating size and packing...
Feb 27, 2022 4:53:37 AM biz.ganttproject.LoggerImpl debug
FINE: 6. changing language ...
FINE: 8. finalizing...
Feb 27, 2022 4:53:38 AM net.sourceforge.ganttproject.GPLogger log
Feb 27, 2022 4:54:01 AM net.sourceforge.ganttproject.GPLogger logToLogger
WARNING: The string "--" is not permitted within comments.
org.xml.sax.SAXParseException; lineNumber: 19; columnNumber: 9; The string "--" is not permitted within comments.
at java.xml/com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLScanner.scanComment(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanComment(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at java.xml/javax.xml.parsers.SAXParser.parse(Unknown Source)
at net.sourceforge.ganttproject.io.XmlParser.parse(XmlParser.java:119)
at net.sourceforge.ganttproject.calendar.GPCalendarProvider.readCalendar(GPCalendarProvider.java:82)
at net.sourceforge.ganttproject.calendar.HolidayCalendarKt.loadCalendars(HolidayCalendar.kt:56)
at net.sourceforge.ganttproject.calendar.GPCalendarProvider.readCalendars(GPCalendarProvider.java:91)
at net.sourceforge.ganttproject.calendar.GPCalendarProvider.getInstance(GPCalendarProvider.java:96)
at net.sourceforge.ganttproject.gui.projectwizard.WeekendConfigurationPage.createCalendarOption(WeekendConfigurationPage.java:196)
at net.sourceforge.ganttproject.gui.projectwizard.WeekendConfigurationPage.<init>(WeekendConfigurationPage.java:139)
at net.sourceforge.ganttproject.gui.projectwizard.NewProjectWizardWindow.addWeekendConfigurationPage(NewProjectWizardWindow.java:52)
at net.sourceforge.ganttproject.gui.projectwizard.NewProjectWizard.createNewProject(NewProjectWizard.java:33)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.showNewProjectWizard(ProjectUIFacadeImpl.kt:279)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.createProject(ProjectUIFacadeImpl.kt:274)
at net.sourceforge.ganttproject.GanttProject.newProject(GanttProject.java:520)
at net.sourceforge.ganttproject.action.project.NewProjectAction.actionPerformed(NewProjectAction.java:44)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/com.apple.laf.ScreenMenuItem.actionPerformed(Unknown Source)
at java.desktop/java.awt.MenuItem.processActionEvent(Unknown Source)
at java.desktop/java.awt.MenuItem.processEvent(Unknown Source)
at java.desktop/java.awt.MenuComponent.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.MenuComponent.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
java.io.IOException: The string "--" is not permitted within comments.
at net.sourceforge.ganttproject.io.XmlParser.parse(XmlParser.java:124)
