When hovering over exception days (holidays, week-end exceptions, etc…) an infotip comes up with the name of the exception. Unfortunately, it does often remain, and it is not possible to let it diappear otherwise than closing the program. I am working on MacOS and this behaviour concerns the MacOS App as well as the platform independent version.
Is it possible to correct this, or to deactivate the infotips (should also be an acceptable option for me) ?
Currently there 's no way to switch these tooltips off, sorry. There is an existing issue in the tracker (it is about notes tooltips, but the underlying code is the same):
Chances are that it will be fixed in the upcoming GP 3.0.
