I’m trying to import a CSV and based on From email: import from CSV - #2 by DmitryBarashev it seems that exporting the same project and then importing it should work. However, when I do that I get an error:
The header contains a duplicate entry: ‘ID’ in [ID, ID, Name, Default role, e-mail, Phone, Standard rate, Total cost, Total load]
Full log
WARNING: The header contains a duplicate entry: ‘ID’ in [ID, ID, Name, Default role, e-mail, Phone, Standard rate, Total cost, Total load]
java.lang.IllegalArgumentException: The header contains a duplicate entry: ‘ID’ in [ID, ID, Name, Default role, e-mail, Phone, Standard rate, Total cost, Total load]
at org.apache.commons.csv.CSVFormat.(CSVFormat.java:368)
at org.apache.commons.csv.CSVFormat.withHeader(CSVFormat.java:877)
at biz.ganttproject.impex.csv.GanttCSVOpen.createCSVFormat(GanttCSVOpen.java:237)
at biz.ganttproject.impex.csv.GanttCSVOpen.createReader(GanttCSVOpen.java:223)
at biz.ganttproject.impex.csv.GanttCSVOpen.load(GanttCSVOpen.java:201)
at biz.ganttproject.impex.csv.ImporterFromCsvFile.run(ImporterFromCsvFile.java:73)
at net.sourceforge.ganttproject.importer.FileChooserPage$1.run(FileChooserPage.java:86)
at net.sourceforge.ganttproject.wizard.AbstractWizard.onOkPressed(AbstractWizard.java:161)
at net.sourceforge.ganttproject.wizard.AbstractWizard$3.actionPerformed(AbstractWizard.java:89)
at net.sourceforge.ganttproject.DialogBuilder$1$1.run(DialogBuilder.java:148)
at java.desktop/java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.desktop/java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.desktop/java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.desktop/java.awt.Dialog.show(Unknown Source)
at java.desktop/java.awt.Component.show(Unknown Source)
at java.desktop/java.awt.Component.setVisible(Unknown Source)
at java.desktop/java.awt.Window.setVisible(Unknown Source)
at java.desktop/java.awt.Dialog.setVisible(Unknown Source)
at net.sourceforge.ganttproject.DialogBuilder$DialogImpl.show(DialogBuilder.java:77)
at net.sourceforge.ganttproject.wizard.AbstractWizard.show(AbstractWizard.java:151)
at net.sourceforge.ganttproject.action.project.ProjectImportAction.actionPerformed(ProjectImportAction.java:50)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/com.apple.laf.ScreenMenuItem.actionPerformed(Unknown Source)
at java.desktop/java.awt.MenuItem.processActionEvent(Unknown Source)
at java.desktop/java.awt.MenuItem.processEvent(Unknown Source)
at java.desktop/java.awt.MenuComponent.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.MenuComponent.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
It seems that it is caused by the resources section because that is where ID is repeated. Is there any documentation on the expected format?
Here’s the file that was created by GanttProject when I exported:
HouseBuildingExample.csv (2.9 KB)
