I’m using Ganttproject 3.0.3000 on Apple M1. When attempting to update to 3.0.3005 I receive the error in the image attached. Any way to solve this??
Best regards
Mikael
Best regards
Mikael
Can you post the log contents? Help > View log
Thanks!
ava.class.path: /Applications/GanttProject.app/Contents/app/eclipsito.jar:/Applications/GanttProject.app/Contents/app/lib/javagalician.jar
java.home: /Applications/GanttProject.app/Contents/runtime/Contents/Home
java.ext.dirs: null
java.io.tmpdir: /var/folders/h_/wf_69h290590r25_2dx8xssc0000gn/T/
java.runtime.version: 11.0.9.1+1-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 11.0.9.1+1-LTS
os.arch: x86_64
os.name: Mac OS X
os.version: 10.16
sun.java.command: com.bardsoftware.eclipsito.Launch --verbosity 4 --version-dirs plugins:~/.ganttproject.d/updates --app net.sourceforge.ganttproject.GanttProject
user.country: SE
user.dir: /Applications/GanttProject.app/Contents/app
user.home: /Users/mikaelericsson
user.language: sv
user.timezone: Europe/Stockholm
mars 30, 2021 11:08:37 FM net.sourceforge.ganttproject.GPLogger log
mars 30, 2021 11:08:38 FM biz.ganttproject.LoggerImpl debug
FIN: Creating main frame…
FIN: 1. loading look’n’feels
mars 30, 2021 11:08:39 FM biz.ganttproject.LoggerImpl debug
FIN: 2. loading options
FIN: 3. creating menus…
FIN: 4. creating views…
FIN: 5. calculating size and packing…
mars 30, 2021 11:08:40 FM biz.ganttproject.LoggerImpl debug
FIN: 6. changing language …
FIN: 7. first attempt to restore bounds
FIN: 8. finalizing…
mars 30, 2021 11:08:50 FM net.sourceforge.ganttproject.GPLogger logToLogger
VARNING: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
java.util.concurrent.CompletionException: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/java.util.concurrent.CompletableFuture.encodeRelay(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeRelay(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniCompose.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeExceptionally(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate.stopOnError(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.uniExceptionally(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniExceptionally.tryFire(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SubscriberWrapper$DownstreamPusher.run1(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SubscriberWrapper$DownstreamPusher.run(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SequentialScheduler$SynchronizedRestartableTask.run(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SequentialScheduler$CompleteRestartableTask.run(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SequentialScheduler$SchedulableTask.run(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SequentialScheduler.runOrSchedule(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SubscriberWrapper.errorCommon(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SubscriberWrapper.onError(Unknown Source)
at java.net.http/jdk.internal.net.http.SocketTube$InternalReadPublisher$ReadSubscription.signalCompletion(Unknown Source)
at java.net.http/jdk.internal.net.http.SocketTube$InternalReadPublisher$InternalReadSubscription.read(Unknown Source)
at java.net.http/jdk.internal.net.http.SocketTube$SocketFlowTask.run(Unknown Source)
at java.net.http/jdk.internal.net.http.SocketTube$InternalReadPublisher$InternalReadSubscription.handleError(Unknown Source)
at java.net.http/jdk.internal.net.http.SocketTube$InternalReadPublisher.signalError(Unknown Source)
at java.net.http/jdk.internal.net.http.SocketTube$InternalWriteSubscriber.signalError(Unknown Source)
at java.net.http/jdk.internal.net.http.SocketTube$InternalWriteSubscriber.onError(Unknown Source)
at java.net.http/jdk.internal.net.http.SocketTube.onError(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate$Writer.processData(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate$Writer$WriterDownstreamPusher.run(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate$Writer.schedule(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate.resumeActivity(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate.lambda$executeTasks$3(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientImpl$DelegatingExecutor.execute(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate.executeTasks(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate.doHandshake(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate$Reader.processData(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SSLFlowDelegate$Reader$ReaderDownstreamPusher.run(Unknown Source)
at java.net.http/jdk.internal.net.http.common.SequentialScheduler$TryEndDeferredCompleter.complete(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source)
at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source)
at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source)
at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.SSLEngineImpl$DelegatedTask$DelegatedAction.run(Unknown Source)
at java.base/sun.security.ssl.SSLEngineImpl$DelegatedTask.run(Unknown Source)
at java.base/java.util.ArrayList.forEach(Unknown Source)
… 14 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source)
at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source)
at java.base/sun.security.validator.Validator.validate(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source)
… 24 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source)
at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source)
at java.base/java.security.cert.CertPathBuilder.build(Unknown Source)
… 30 more
Any suggestions on how to solve this?
Thanks in advance
I have no idea why it happens (and why it does not happen to other macOS users) and if there is any easy user-friendly way how to convince your system t o trust the SSL certificate.
However, we can try to test if it works when update files are delivered from other domains. You will need to find .ganttproject file in your home folder and change one line. Let me know if this sounds good.
Hi!
Thanks! OK, sounds great, I think I can manage that
Regards
Mikael
