Hi! I’m trying to use the beta version, I installed ganttproject_2.99-r2906-1_all.deb
I also installed the java 11 and the bellsoft version using sdkman: sdk install java 11.0.9.fx-librca
If I run echo $JAVA_HOME I get
/home/raquelhortab/.sdkman/candidates/java/current
and if I run java -version I get
openjdk version "11.0.9.1" 2020-11-04 LTS
OpenJDK Runtime Environment (build 11.0.9.1+1-LTS)
OpenJDK 64-Bit Server VM (build 11.0.9.1+1-LTS, mixed mode)
However, if I try to run ganttproject I get
/usr/share/ganttproject/runtime/bin/java does not exist
Any idea what the problem could be?
