for a project, I need to open different *.gan files from Excel, Export the data and import it into an Excel-File, where I need to process some of this data further.
Is there any possibility to do so from VBA side? So far I have not found any working code.
Thanks a lot.
You can just export data from GanttProject to CSV file instead.
If you really need to do it programmatically, you can start ganttproject executable with command line aguments. I didn’t try it on Windows, but on Linux the following produces CSV from .gan:
ganttproject -export csv ./MyProjectFile.gan
I do Need to open it with Excel, as I Need to gather data out of various *.gan’s and process this data. The whole Thing should run automated. Once I get it exported as csv, it is not a Problem anymore.
So, try executing this export command from VBA script.
