Visual suggestions and questions to priority
Hi everybody,
I like GANTT very much since it is easy to use and focuses on the important things a diagram should provide.
Now, I have som suggestions/questions to the developers:
  1. is it possible to put the text in the task column not only ABOVE oder BELOW but IN the column itself?! Would save some paper space :wink:
  2. change the color of all subtasks in one step (from a special task) by marking all of them.
  3. I created an additional Column beside Duration named PRIORITY. When changing the prioritiy of different tasks ( high, low etc.) nothing happens in the cell behind the task…how do I make it red for highest priority (and so on)
    Looking forward to your answers/suggestions :slight_smile:
    Thanks, Arthur
Export it to Excel and make a new sheet with the ā€œmakeupā€ ; )
I don’t understand the question. What is ā€œtask columnā€?
No, sorry, editing of properties of multiple tasks is not yet supported.
I don’t understand if you’re talking about the built-in Priority column or about your own, and what did you mean by ā€œnothing happens in the cell behind the taskā€, but anyway, the only property which changes any colors is ā€œtask colorā€, sorry.
grafik
Pictures say more than 1000 words :wink: Hope the image is shown
Text in bar
Text in the bar, not ABOVE :slight_smile:
