Hi there,
an I/O error message appears when trying to save or open a project file to my NAS via WebDAV.
It´s a Synology NAS and I am using port 5006 for a https connection. The WebDAV server on my NAS runs fine as access to it für e. g. DevonThinkPro does not show any errors…
This is the short error message:
"Irgendetwas ist schiefgegangen [Something went wrong]
I/O problems when accessing NAS https: nodename nor servname provided, or not known
Protokoll anzeigen"
Log file:
"/Users/cnaehle/ganttproject.log
GanttProject 2.8.4 Pilsen (build 2134)
java.class.path: /private/var/folders/dz/2tb44jx16v79fz4whcbm3gcr0000gn/T/AppTranslocation/42475C76-B964-47DB-95E3-D8CCE032F0C3/d/GanttProject.app/Contents/Java/Classes:/private/var/folders/dz/2tb44jx16v79fz4whcbm3gcr0000gn/T/AppTranslocation/42475C76-B964-47DB-95E3-D8CCE032F0C3/d/GanttProject.app/Contents/Java/eclipsito.jar
java.home: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home
java.ext.dirs: /Users/cnaehle/Library/Java/Extensions:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/ext:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
java.io.tmpdir: /var/folders/dz/2tb44jx16v79fz4whcbm3gcr0000gn/T/
java.runtime.version: 1.8.0_121-b13
java.vm.name: Java HotSpot™ 64-Bit Server VM
java.vm.version: 25.121-b13
os.arch: x86_64
os.name: Mac OS X
os.version: 10.12.3
sun.java.command: org.bardsoftware.eclipsito.Boot -app net.sourceforge.ganttproject.GanttProject -plugins-dir /private/var/folders/dz/2tb44jx16v79fz4whcbm3gcr0000gn/T/AppTranslocation/42475C76-B964-47DB-95E3-D8CCE032F0C3/d/GanttProject.app/Contents/Java/plugins-2.8.4 -log true
user.country: DE
user.dir: /Users/cnaehle
user.home: /Users/cnaehle
user.language: de
user.timezone: Europe/Zurich
Mär 29, 2017 10:35:44 AM net.sourceforge.ganttproject.GPLogger log
INFORMATION: Options file:/Users/cnaehle/.ganttproject
Mär 29, 2017 10:35:45 AM net.sourceforge.ganttproject.GPLogger log
INFORMATION: Waiting until main window closes
INFORMATION: Deleting old auto-save files
Creating main frame…
- loading look’n’feels
no editor for column=2 class=interface javax.swing.Icon - loading options
- creating menus…
- creating views…
- changing language …
Mär 29, 2017 10:35:49 AM net.sourceforge.ganttproject.GPLogger log
INFORMATION: Bounds stored in the options: java.awt.Rectangle[x=0,y=22,width=1440,height=823] - finalizing…
Main frame created
INFORMATION: Bounds after setVisible: java.awt.Rectangle[x=0,y=23,width=1440,height=823]
Splash closed
Resizing window…
INFORMATION: Bounds after opening: java.awt.Rectangle[x=0,y=23,width=1440,height=823]
Mär 29, 2017 10:35:54 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
INFORMATION: Scanning font directories…
Mär 29, 2017 10:35:54 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFORMATION: scanning directory=/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/fonts
INFORMATION: scanning directory=C:/windows/fonts
INFORMATION: directory C:/windows/fonts is not readable
INFORMATION: scanning directory=/usr/share/fonts/truetype
INFORMATION: directory /usr/share/fonts/truetype is not readable
INFORMATION: scanning directory=/System/Library/Fonts
Mär 29, 2017 10:35:56 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFORMATION: scanning directory=/private/var/folders/dz/2tb44jx16v79fz4whcbm3gcr0000gn/T/AppTranslocation/42475C76-B964-47DB-95E3-D8CCE032F0C3/d/GanttProject.app/Contents/Java/plugins-2.8.4/org.ganttproject.impex.htmlpdf/resource/fonts
Mär 29, 2017 10:35:56 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
INFORMATION: Scanning font directories completed
Mär 29, 2017 10:36:01 AM net.sourceforge.ganttproject.GPLogger logToLogger
WARNUNG: I/O problems when accessing naehle.internet-box.ch
net.sourceforge.ganttproject.document.webdav.WebDavResource$WebDavException: I/O problems when accessing naehle.internet-box.ch
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.getOptionalImpl(MiltonResourceImpl.java:119)
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.exists(MiltonResourceImpl.java:82)
at net.sourceforge.ganttproject.document.webdav.GanttURLChooser$ReloadWorker.doInBackground(GanttURLChooser.java:272)
at net.sourceforge.ganttproject.document.webdav.GanttURLChooser$ReloadWorker.doInBackground(GanttURLChooser.java:261)
at javax.swing.SwingWorker$1.call(SwingWorker.java:295)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at javax.swing.SwingWorker.run(SwingWorker.java:334)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
at sun.security.ssl.SSLSessionImpl.getPeerCertificates(SSLSessionImpl.java:431)
at org.apache.http.conn.ssl.AbstractVerifier.verify(AbstractVerifier.java:128)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:572)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:180)
at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:151)
at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:125)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:640)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:479)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:906)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:1066)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:1044)
at io.milton.httpclient.Host._doPropFind(Host.java:628)
at io.milton.httpclient.Folder.children(Folder.java:131)
at io.milton.httpclient.Folder.child(Folder.java:351)
at io.milton.httpclient.Host._find(Host.java:263)
at io.milton.httpclient.Host.find(Host.java:255)
at io.milton.httpclient.Host.find(Host.java:244)
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.getOptionalImpl(MiltonResourceImpl.java:109)
… 9 more
Mär 29, 2017 10:36:05 AM net.sourceforge.ganttproject.GPLogger logToLogger
WARNUNG: I/O problems when accessing NAS
net.sourceforge.ganttproject.document.webdav.WebDavResource$WebDavException: I/O problems when accessing NAS
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.getChildResources(MiltonResourceImpl.java:220)
at net.sourceforge.ganttproject.document.webdav.GanttURLChooser$ReloadWorker.readChildren(GanttURLChooser.java:288)
at net.sourceforge.ganttproject.document.webdav.GanttURLChooser$ReloadWorker.doInBackground(GanttURLChooser.java:273)
Caused by: java.net.UnknownHostException: https: nodename nor servname provided, or not known
at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:928)
at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1323)
at java.net.InetAddress.getAllByName0(InetAddress.java:1276)
at java.net.InetAddress.getAllByName(InetAddress.java:1192)
at java.net.InetAddress.getAllByName(InetAddress.java:1126)
at org.apache.http.impl.conn.SystemDefaultDnsResolver.resolve(SystemDefaultDnsResolver.java:45)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.resolveHostname(DefaultClientConnectionOperator.java:278)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:162)
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.getChildResources(MiltonResourceImpl.java:209)
… 9 more
Mär 29, 2017 10:36:11 AM net.sourceforge.ganttproject.GPLogger logToLogger
WARNUNG: null
java.lang.AssertionError
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.getInputStream(MiltonResourceImpl.java:271)
at net.sourceforge.ganttproject.document.webdav.HttpDocument.getInputStream(HttpDocument.java:175)
at net.sourceforge.ganttproject.document.ProxyDocument.getInputStream(ProxyDocument.java:127)
at net.sourceforge.ganttproject.document.ProxyDocument$ParsingState.enter(ProxyDocument.java:355)
at net.sourceforge.ganttproject.document.ProxyDocument.read(ProxyDocument.java:178)
at net.sourceforge.ganttproject.GanttProject.open(GanttProject.java:687)
at net.sourceforge.ganttproject.gui.ProjectOpenStrategy.openFileAsIs(ProjectOpenStrategy.java:119)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.openProject(ProjectUIFacadeImpl.java:248)
at net.sourceforge.ganttproject.action.project.OpenURLAction.openRemoteProject(OpenURLAction.java:57)
at net.sourceforge.ganttproject.action.project.OpenURLAction.actionPerformed(OpenURLAction.java:45)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at com.apple.laf.ScreenMenuItem.actionPerformed(ScreenMenuItem.java:125)
at java.awt.MenuItem.processActionEvent(MenuItem.java:669)
at java.awt.MenuItem.processEvent(MenuItem.java:628)
at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:355)
at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:343)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:761)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Mär 29, 2017 10:40:25 AM net.sourceforge.ganttproject.GPLogger logToLogger
… 9 more"
Any suggestions?
Regards
Philip
