GanttProject 2.8.9.
On some computers, the WebDAV server access window does not open.
(NB : on other computers, GanttProject 2.8.9 has perfect access to the same server.)
The problem appears on Windows or Ios machines with different versions of Java.
Any help will be welcome.
Thanx,
H.
Here is the log of the application (Windows 8.1) :
GanttProject 2.8.9 Pilsen (build 2335)
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-2.8
java.home: C:\Program Files\Java\jre7
java.ext.dirs: C:\Program Files\Java\jre7\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.io.tmpdir: C:\Users\GUILLA~1\AppData\Local\Temp
java.runtime.version: 1.7.0_10-b18
java.vm.name: Java HotSpot™ 64-Bit Server VM
java.vm.version: 23.6-b04
os.arch: amd64
os.name: Windows 8
os.version: 6.2
sun.java.command: org.bardsoftware.eclipsito.Boot ganttproject-eclipsito-config.xml -log true
user.country: FR
user.dir: C:\Program Files (x86)\GanttProject-2.8
user.home: C:\Users\Guillaume
user.language: fr
user.timezone: Europe/Paris
janv. 17, 2019 10:45:53 AM net.sourceforge.ganttproject.GPLogger log
INFO: Options file:C:\Users\Guillaume.ganttproject
janv. 17, 2019 10:45:55 AM net.sourceforge.ganttproject.GPLogger log
janv. 17, 2019 10:46:02 AM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
janv. 17, 2019 10:46:02 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=C:\Program Files\Java\jre7/lib/fonts
janv. 17, 2019 10:46:06 AM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
Creating main frame…
- loading look’n’feels
no editor for column=2 class=interface javax.swing.Icon - loading options
- creating menus…
- creating views…
- changing language …
janv. 17, 2019 10:47:07 AM net.sourceforge.ganttproject.GPLogger log
INFO: Bounds stored in the options: java.awt.Rectangle[x=-8,y=-8,width=1382,height=744] - finalizing…
Main frame created
INFO: Bounds after setVisible: java.awt.Rectangle[x=-8,y=-8,width=1382,height=744]
Splash closed
Resizing window…
janv. 17, 2019 10:47:15 AM net.sourceforge.ganttproject.GPLogger log
INFO: Bounds after opening: java.awt.Rectangle[x=-8,y=-8,width=1382,height=744]
janv. 17, 2019 10:47:29 AM net.sourceforge.ganttproject.GPLogger log
janv. 17, 2019 10:49:28 AM net.sourceforge.ganttproject.GPLogger logToLogger
WARNING: null
java.lang.AssertionError
at net.sourceforge.ganttproject.document.webdav.WebDavUri.(WebDavUri.java:64)
at net.sourceforge.ganttproject.document.webdav.WebDavStorageImpl.createChooser(WebDavStorageImpl.java:274)
at net.sourceforge.ganttproject.document.webdav.WebDavStorageImpl.open(WebDavStorageImpl.java:210)
at net.sourceforge.ganttproject.action.project.CloudProjectActionBase.showURLDialog(CloudProjectActionBase.java:55)
at net.sourceforge.ganttproject.action.project.OpenURLAction.openRemoteProject(OpenURLAction.java:58)
at net.sourceforge.ganttproject.action.project.OpenURLAction.actionPerformed(OpenURLAction.java:48)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
On Ios 10.14, please see screenshots
