Thank you for your reply. Unfortunately, there is no slash at the end of the URL.
But it gave me the idea to look at the configuration file.
And I saw this:
The value value = "http: // & # 9; / is inherited from the default value present when entering the Webdav server URL. I do not know how this value is present in the configuration file, but it’s the one that blocks I think.
Indeed, I replaced this value by the correct address of the server and everything is back in order on the Windows computers.
On the other hand, I can not find the configuration file on an IOS computer.
Can you tell me where to look.
Thank you very much for your availability. And thank you for your work on this application.
Regards,
H.
