Hello.
I have an excel file properly configured, but when I import the file, the ‘notes’ field is not imported, remaining blank in the GanttProject.
Steps I’ve already done:
I exported an xls from ganttproject and manually filled in the notes column and then imported it again and everything went well;
I exported an xls and then copied the notes from another file, using “paste values only”, and the notes were no longer imported.
I exported an xls and then copied the notes from another file, leaving the first line unchanged, then copied the formatting of the first line to the others and I was able to import the notes.
(note: the file extension is always the same = office97-2003 xls)
What could be happening?
Thanks for the help.
