Build & Launch works with gradle[w] but no standalone application (Windows)
I successfully build the latest version of GanttProject with instructions from here https://docs.ganttproject.biz/development/build/index.html
The launch works with gradle or gradlew but the standalone app crash.
What am I doing wrong ?
> .\gradlew.bat distbin => build ok
> .\gradlew.bat runApp => run ok (with english menus)
> cd ganttproject-builder\dist-bin
\ganttproject-builder\dist-bin>ganttproject.bat
Exception in thread "main" java.lang.NullPointerException
        at com.bardsoftware.eclipsito.Launch.getVersionLayerStoreDirs(Launch.java:123)
        at com.bardsoftware.eclipsito.Launch.main(Launch.java:80)
From here (Reduce code building time) I try gradle :ganttproject:run
> gradle :ganttproject:run  => run ok, in french and without settings dialog (as expected)
Version :
\ganttproject> git status
On branch master
Your branch is up to date with 'origin/master'.
\ganttproject> gradlew.bat -v
Gradle 5.4.1
Build time:   2019-04-26 08:14:42 UTC
Revision:     261d171646b36a6a28d5a19a69676cd098a4c19d
Kotlin:       1.3.21
Groovy:       2.5.4
Ant:          Apache Ant(TM) version 1.9.13 compiled on July 10 2018
JVM:          11.0.6 (Oracle Corporation 11.0.6+8-LTS)
OS:           Windows 10 10.0 amd64
ganttproject> java -version
java version "11.0.6" 2020-01-14 LTS
Java(TM) SE Runtime Environment 18.9 (build 11.0.6+8-LTS)
Java HotSpot(TM) 64-Bit Server VM 18.9 (build 11.0.6+8-LTS, mixed mode)
