Could anyone have a quick look at my CSV file?
I don’t manage to assign a resource to a task correctly.
That would be extremely nice!
Export (17).csv (1.1 KB)
Nice file. It imports without any issues. What do you want us to look at?
Thanks Dmitry !
When I import it in a new project, the resources are not assigned to the related task.
More specifically, for theses tasks :
0,task_2,8/28/19,8/28/19,2,0,0,X1,1,X1,0:80.00,
1,task_3,8/28/19,8/28/19,1,0,0,X1,1,X1,0:100.00,
2,task_4,8/28/19,8/28/19,1,0,0,X2,0,1,X2,0:100.00,
3,task_5,8/28/19,8/28/19,1,0,0,X2,1,1,X2,1:80.00,
4,task_6,8/28/19,8/28/19,1,0,0,X2,2,1,X2,1:80.00,
I expected the task 2 to 6 to be assigned to X1 and X2.
I believe that the field Assignements is :
id_resource:unit
Is this correct ?
The Gantt and the Resources are correctly imported, but the resources are not assigned to the task.
I can’t figure out what I’m missing ![]()
I’m running GanttProject 2.8.10 Pilsen (build 2363)
It works perfectly in my test:
<id_resource>:
Is this correct ?
<resource_id>:<load> to be correct.
Strange, I restarted GanttProject and I managed to get the same result.
I could see also that the “error” I had in the bottom right end corner disappeared.
Maybe GanttProject was in a weird state after a failed import that didn’t restore when I created a new project.
There is still a remaining issue though.
I can see it in your screenshot.
The load for each resource is incorrect.
It should be 80 or 100 right ?
I only manage to get this 0%.
