Hello! I’d like to build your app from sources but for some reason I get performance issues on git/ganttproject-3.3.3316 (master version seems to be not working properly)
I’m using JDK FX optimized for silicon arch - azul JDK FX 17
/usr/libexec/java_home -V
Matching Java Virtual Machines (5):
21.0.7 (arm64) "Azul Systems, Inc." - "Zulu 21.42.19" /Library/Java/JavaVirtualMachines/zulu-21.jdk/Contents/Home
17.0.15 (arm64) "Azul Systems, Inc." - "Zulu JRE 17.58.21" /Library/Java/JavaVirtualMachines/zulu-17.jre/Contents/Home
17.0.15 (arm64) "Azul Systems, Inc." - "Zulu 17.58.21" /Library/Java/JavaVirtualMachines/zulu-17.jdk/Contents/Home
17.0.15+10-LTS (arm64) "BellSoft" - "BellSoft Liberica JDK 17.0.15+10" /Library/Java/JavaVirtualMachines/liberica-jdk-17-full.jdk/Contents/Home
1.8.451.10 (arm64) "Oracle Corporation" - "Java" /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home
JAVA_HOME:
echo ${JAVA_HOME}
/Users/andrei.kiselev/.jenv/versions/zulu64-17.0.15
Performance issue is the same as in the post here:
I’m trying to build the app with this Prism specified flags:
JAVA_OPTS="-Dprism.order=es2,sw -Dprism.verbose=true -Dprism.maxvram=4096M -Danimation.fullspeed=true -Dprism.vsync=false" ./gradlew runApp
But It doesn’t work as I expect - lagging in the gantt tab is still occur
Prebuilt silicon app works flawless, but I’m interested in building software from scratch and can not figure out root cause of the issue
Could you please share recommendations on how does current sillicon dmg optimized for flawless animations and without a lag
