C:\Users\janwillem\ganttproject.log
GanttProject 2.8.11 Pilsen (build 2396)
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-2.8
java.home: C:\Program Files\Java\jre1.8.0_261
java.ext.dirs: C:\Program Files\Java\jre1.8.0_261\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.io.tmpdir: C:\Users\JANWIL~1\AppData\Local\Temp
java.runtime.version: 1.8.0_261-b12
java.vm.name: Java HotSpot™ 64-Bit Server VM
java.vm.version: 25.261-b12
os.arch: amd64
os.name: Windows 10
os.version: 10.0
sun.java.command: org.bardsoftware.eclipsito.Boot -plugins-dir plugins -app net.sourceforge.ganttproject.GanttProject -log true
user.country: NL
user.dir: C:\Program Files (x86)\GanttProject-2.8
user.home: C:\Users\janwillem
user.language: nl
user.timezone: Europe/Berlin
jul 20, 2020 3:13:22 PM net.sourceforge.ganttproject.GPLogger log
INFO: Options file:C:\Users\janwillem.ganttproject
jul 20, 2020 3:13:23 PM net.sourceforge.ganttproject.GPLogger log
Creating main frame…
- loading look’n’feels
no editor for column=2 class=interface javax.swing.Icon - loading options
- creating menus…
- creating views…
jul 20, 2020 3:13:25 PM net.sourceforge.ganttproject.GPLogger logToLogger
WARNING: Can’t create an ImageInputStream!
javax.imageio.IIOException: Can’t create an ImageInputStream!
at javax.imageio.ImageIO.read(Unknown Source)
at net.sourceforge.ganttproject.UIFacadeImpl.getLogo(UIFacadeImpl.java:684)
at net.sourceforge.ganttproject.ChartTabContentPanel.createContentComponent(ChartTabContentPanel.java:77)
at net.sourceforge.ganttproject.GanttChartTabContentPanel.getComponent(GanttChartTabContentPanel.java:78)
at net.sourceforge.ganttproject.GanttChartTabContentPanel.getViewComponent(GanttChartTabContentPanel.java:127)
at net.sourceforge.ganttproject.gui.view.ViewHolder.setVisible(ViewHolder.java:66)
at net.sourceforge.ganttproject.gui.view.ViewManagerImpl.toggleVisible(ViewManagerImpl.java:147)
at net.sourceforge.ganttproject.GanttProject.(GanttProject.java:350)
at net.sourceforge.ganttproject.GanttProject$15.run(GanttProject.java:1021)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
at net.sourceforge.ganttproject.ResourceChartTabContentPanel.getComponent(ResourceChartTabContentPanel.java:30)
at net.sourceforge.ganttproject.ResourceChartTabContentPanel.getViewComponent(ResourceChartTabContentPanel.java:64)
at net.sourceforge.ganttproject.GanttProject.(GanttProject.java:355)
- changing language …
INFO: Bounds stored in the options: java.awt.Rectangle[x=1916,y=-6,width=1936,height=1066] - finalizing…
Main frame created
INFO: Bounds after setVisible: java.awt.Rectangle[x=1916,y=-6,width=1936,height=1066]
Splash closed
Resizing window…
INFO: Bounds after opening: java.awt.Rectangle[x=1916,y=-6,width=1936,height=1066]
jul 20, 2020 3:13:31 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
jul 20, 2020 3:13:31 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=C:\Program Files\Java\jre1.8.0_261/lib/fonts
jul 20, 2020 3:13:32 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
java.util.concurrent.ExecutionException: java.lang.NoClassDefFoundError: org/apache/commons/codec/binary/Base64
at java.util.concurrent.FutureTask.report(Unknown Source)
at java.util.concurrent.FutureTask.get(Unknown Source)
at javax.swing.SwingWorker.get(Unknown Source)
at net.sourceforge.ganttproject.document.webdav.GanttURLChooser$ReloadWorker.done(GanttURLChooser.java:304)
at javax.swing.SwingWorker$5.run(Unknown Source)
at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at sun.swing.AccumulativeRunnable.run(Unknown Source)
at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at javax.swing.Timer.fireActionPerformed(Unknown Source)
at javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at net.sourceforge.ganttproject.DialogBuilder$DialogImpl.show(DialogBuilder.java:148)
at net.sourceforge.ganttproject.action.project.CloudProjectActionBase.showURLDialog(CloudProjectActionBase.java:57)
at net.sourceforge.ganttproject.action.project.OpenURLAction.openRemoteProject(OpenURLAction.java:58)
at net.sourceforge.ganttproject.action.project.OpenURLAction.actionPerformed(OpenURLAction.java:48)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: org/apache/commons/codec/binary/Base64
at org.apache.http.impl.auth.GGSSchemeBase.(GGSSchemeBase.java:83)
at org.apache.http.impl.auth.SPNegoScheme.(SPNegoScheme.java:52)
at org.apache.http.impl.auth.SPNegoSchemeFactory.newInstance(SPNegoSchemeFactory.java:79)
at org.apache.http.auth.AuthSchemeRegistry.getAuthScheme(AuthSchemeRegistry.java:114)
at org.apache.http.auth.AuthSchemeRegistry$1.create(AuthSchemeRegistry.java:151)
at org.apache.http.impl.client.AuthenticationStrategyImpl.select(AuthenticationStrategyImpl.java:189)
at org.apache.http.impl.client.TargetAuthenticationStrategy.select(TargetAuthenticationStrategy.java:44)
at org.apache.http.impl.auth.HttpAuthenticator.handleAuthChallenge(HttpAuthenticator.java:151)
at org.apache.http.impl.client.HttpAuthenticator.authenticate(HttpAuthenticator.java:58)
at org.apache.http.impl.client.DefaultRequestDirector.handleResponse(DefaultRequestDirector.java:1051)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:509)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:835)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:72)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:221)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:165)
at io.milton.httpclient.Host._doPropFind(Host.java:656)
at io.milton.httpclient.Folder.children(Folder.java:131)
at io.milton.httpclient.Folder.child(Folder.java:351)
at io.milton.httpclient.Host._find(Host.java:286)
at io.milton.httpclient.Host.find(Host.java:278)
at io.milton.httpclient.Host.find(Host.java:267)
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.getOptionalImpl(MiltonResourceImpl.java:105)
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.exists(MiltonResourceImpl.java:78)
at net.sourceforge.ganttproject.document.webdav.GanttURLChooser$ReloadWorker.doInBackground(GanttURLChooser.java:272)
at net.sourceforge.ganttproject.document.webdav.GanttURLChooser$ReloadWorker.doInBackground(GanttURLChooser.java:261)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: org.apache.commons.codec.binary.Base64
at java.net.URLClassLoader.findClass(Unknown Source)
at org.bardsoftware.impl.eclipsito.BundleClassLoader.findClass(BundleClassLoader.java:131)
at java.lang.ClassLoader.loadClass(Unknown Source)
… 31 more
jul 20, 2020 3:13:35 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=/C:/Program Files (x86)/GanttProject-2.8/plugins/2.8.11/org.ganttproject.impex.htmlpdf/resource/fonts
jul 20, 2020 3:13:35 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
jul 20, 2020 3:13:37 PM net.sourceforge.ganttproject.GPLogger logToLogger
WARNING: org/apache/commons/codec/binary/Base64
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.assertExists(MiltonResourceImpl.java:86)
at net.sourceforge.ganttproject.document.webdav.MiltonResourceImpl.getInputStream(MiltonResourceImpl.java:267)
at net.sourceforge.ganttproject.document.webdav.HttpDocument.getInputStream(HttpDocument.java:175)
at net.sourceforge.ganttproject.document.ProxyDocument.getInputStream(ProxyDocument.java:127)
at net.sourceforge.ganttproject.document.ProxyDocument$ParsingState.enter(ProxyDocument.java:355)
at net.sourceforge.ganttproject.document.ProxyDocument.read(ProxyDocument.java:178)
at net.sourceforge.ganttproject.GanttProject.open(GanttProject.java:752)
at net.sourceforge.ganttproject.gui.ProjectOpenStrategy.openFileAsIs(ProjectOpenStrategy.java:119)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.openProject(ProjectUIFacadeImpl.java:248)
at net.sourceforge.ganttproject.action.project.OpenURLAction.openRemoteProject(OpenURLAction.java:60)
