I tried to search previous discussions but none of them seems to help.
I try to run ggant project, loading window will open also icon into the taskbar, and then closes. But in the task manager, it shows that it’s running.
Please help!
Please help!
Is there anything in the log file? The log file is ganttproject.log and it sits in your home folder.
You home folder is C:\Users\oliver
There is several logs.
Kontakt Dmitry Barashev via GanttProject Support (<[email protected]>) kirjutas kuupäeval R, 2. oktoober 2020 kell 20:34:
(Attachment ganttproject.log.7 is missing)
(Attachment ganttproject.log.1 is missing)
(Attachment ganttproject.log.4 is missing)
(Attachment ganttproject.log.2 is missing)
(Attachment ganttproject.log.3 is missing)
(Attachment ganttproject.log.5 is missing)
(Attachment ganttproject.log.6 is missing)
You need one with the name ganttproject.log, with no other extensions, produced right after the attempt to launch GanttProject.
Oct 01, 2020 9:49:16 PM net.sourceforge.ganttproject.GPLogger log
INFO: Options file:C:\Users\oliver.ganttproject
Oct 01, 2020 9:49:18 PM net.sourceforge.ganttproject.GPLogger log
Oct 01, 2020 9:49:26 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Oct 01, 2020 9:49:26 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=C:\Program Files\Java\jre1.8.0_261/lib/fonts
Oct 01, 2020 9:49:27 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
Oct 01, 2020 9:49:30 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=/C:/Program Files (x86)/GanttProject-2.8/plugins/2.8.11/org.ganttproject.impex.htmlpdf/resource/fonts
Oct 01, 2020 9:49:30 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Oct 01, 2020 10:05:54 PM net.sourceforge.ganttproject.GPLogger log
Oct 01, 2020 10:05:55 PM net.sourceforge.ganttproject.GPLogger log
Oct 01, 2020 10:06:04 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Oct 01, 2020 10:06:04 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
Oct 01, 2020 10:06:06 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
Oct 01, 2020 10:06:06 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Kontakt Dmitry Barashev via GanttProject Support (<[email protected]>) kirjutas kuupäeval L, 3. oktoober 2020 kell 00:08:
Well, it turned out not very useful.
So, we have a couple of articles is the Knowledge Base about issues on Windows. You may try them both: https://github.com/bardsoftware/ganttproject/issues?q=is%3Aissue+is%3Aopen+label%3Aknowledgebase
Also, you may want to try using GanttProject 3.0 beta which comes with Java Runtime version 11 and may work differently. Download it from here: https://www.ganttproject.biz/download#download30
So… I got GanttProject 3.0 working.
Now I have some practical questions.
Basically functions that MS Project has.
Best regards,
Oliver
Kontakt Dmitry Barashev via GanttProject Support (<[email protected]>) kirjutas kuupäeval L, 3. oktoober 2020 kell 21:59:
