I downloaded the new version 3.0. But when I click to run it, nothing happens. When I open task manager, then I can see it’s indeed running. But the application itself never opens. Any idea what would cause this?
Maybe this?
I can’t find the options file “.ganttproject” I’ve turned on the option for showing hidden files in Windows Explorer. And can’t see it anyway. I assume the home director is Ganttproject-3.0 – i.e. where everything is. And not some subfolder.
Your home directory on Windows is something like C:\Users\<your user name here>
Ah! Thank you Well, I found the file. Deleted it. But no change. Same thing. It starts running in that I can see it in Task Manager, but the application itself doesn’t open.
Is there anything in ganttproject.log file in your home directory?
Here’s what’s in that file:
GanttProject 2.8.11 Pilsen (build 2396)
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-2.8
java.home: C:\Program Files\Java\jre1.8.0_281
java.ext.dirs: C:\Program Files\Java\jre1.8.0_281\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.io.tmpdir: C:\Users\davie\AppData\Local\Temp
java.runtime.version: 1.8.0_281-b09
java.vm.name: Java HotSpot™ 64-Bit Server VM
java.vm.version: 25.281-b09
os.arch: amd64
os.name: Windows 10
os.version: 10.0
sun.java.command: org.bardsoftware.eclipsito.Boot -plugins-dir plugins -app net.sourceforge.ganttproject.GanttProject -log true
user.country: GB
user.dir: C:\Program Files (x86)\GanttProject-2.8
user.home: C:\Users\davie
user.language: en
user.timezone: Europe/Helsinki
Mar 01, 2021 1:57:47 PM net.sourceforge.ganttproject.GPLogger log
INFO: Options file:C:\Users\davie.ganttproject
Mar 01, 2021 1:57:48 PM net.sourceforge.ganttproject.GPLogger log
Creating main frame…
- loading look’n’feels
no editor for column=2 class=interface javax.swing.Icon - loading options
- creating menus…
- creating views…
- changing language …
Mar 01, 2021 1:57:49 PM net.sourceforge.ganttproject.GPLogger log
INFO: Bounds stored in the options: java.awt.Rectangle[x=-11,y=-11,width=1300,height=740] - finalizing…
Main frame created
INFO: Bounds after setVisible: java.awt.Rectangle[x=-11,y=-11,width=1300,height=740]
Splash closed
Resizing window…
INFO: Bounds after opening: java.awt.Rectangle[x=-11,y=-11,width=1300,height=740]
Mar 01, 2021 1:57:56 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Mar 01, 2021 1:57:56 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=C:\Program Files\Java\jre1.8.0_281/lib/fonts
Mar 01, 2021 1:57:57 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
Mar 01, 2021 1:57:59 PM org.ganttproject.impex.htmlpdf.fonts.TTFontCache registerDirectory
INFO: scanning directory=/C:/Program Files (x86)/GanttProject-2.8/plugins/2.8.11/org.ganttproject.impex.htmlpdf/resource/fonts
Mar 01, 2021 1:57:59 PM org.ganttproject.impex.htmlpdf.itext.ITextEngine$2 run
Mar 01, 2021 1:59:18 PM net.sourceforge.ganttproject.GPLogger log
INFO: [GanttOptions] save(): finished!!
Mar 01, 2021 1:59:20 PM net.sourceforge.ganttproject.GPLogger log
INFO: Main window has closed
INFO: Program terminated
Apparently, it was produced by GP 2.8.11 which is not that useful.
Can you run ganttproject.bat file from the command line terminal and post what is printed to the output? You need to run it from GanttProject 3.0 installation directory.
I cant migrate from 2.8 to version 3 either. I deleted .ganttproject in the user folder as the presence of the file caused version 3.004 to stall in the splash screen. However, the software launches but cannot save any project or import and save any documents. the attempt to create a new project calls the follwing error.
C:\Users\Hans-Dieter Zucht\ganttproject.log
GanttProject 3.0.3004
is readable: false
java.class.path: eclipsito.jar;C:\Program Files (x86)\GanttProject-3.03\GanttProject-3.0
java.home: C:\Program Files (x86)\GanttProject-3.03\GanttProject-3.0\runtime
java.ext.dirs: null
java.io.tmpdir: C:\Users\HANS-D~1\AppData\Local\Temp
java.runtime.version: 11.0.9.1+1-LTS
java.vendor: BellSoft
java.vm.vendor: BellSoft
java.vm.version: 11.0.9.1+1-LTS
os.arch: amd64
os.name: Windows 10
os.version: 10.0
user.country: DE
user.dir: C:\Program Files (x86)\GanttProject-3.03\GanttProject-3.0
user.home: C:\Users\Hans-Dieter Zucht
user.language: de
user.timezone: Europe/Berlin
März 15, 2021 10:42:11 VORM. biz.ganttproject.LoggerImpl debug
FEIN: Creating main frame…
FEIN: 1. loading look’n’feels
FEIN: 2. loading options
FEIN: 3. creating menus…
FEIN: 4. creating views…
FEIN: 5. calculating size and packing…
FEIN: 6. changing language …
FEIN: 7. first attempt to restore bounds
FEIN: 8. finalizing…
März 15, 2021 10:47:17 VORM. net.sourceforge.ganttproject.GPLogger logToLogger
WARNUNG: INSTANCE
java.lang.NoSuchFieldError: INSTANCE
at net.sourceforge.ganttproject.util.ColorConvertion.determineColor(ColorConvertion.java:34)
at net.sourceforge.ganttproject.parser.HolidayTagHandler.loadHoliday(HolidayTagHandler.java:141)
at net.sourceforge.ganttproject.parser.HolidayTagHandler.endElement(HolidayTagHandler.java:96)
at net.sourceforge.ganttproject.io.XmlParser.endElement(XmlParser.java:82)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at java.xml/javax.xml.parsers.SAXParser.parse(Unknown Source)
at net.sourceforge.ganttproject.io.XmlParser.parse(XmlParser.java:119)
at net.sourceforge.ganttproject.calendar.GPCalendarProvider.readCalendar(GPCalendarProvider.java:82)
at net.sourceforge.ganttproject.calendar.HolidayCalendarKt.loadCalendars(HolidayCalendar.kt:56)
at net.sourceforge.ganttproject.calendar.GPCalendarProvider.readCalendars(GPCalendarProvider.java:91)
at net.sourceforge.ganttproject.calendar.GPCalendarProvider.getInstance(GPCalendarProvider.java:96)
at net.sourceforge.ganttproject.gui.projectwizard.WeekendConfigurationPage.createCalendarOption(WeekendConfigurationPage.java:196)
at net.sourceforge.ganttproject.gui.projectwizard.WeekendConfigurationPage.(WeekendConfigurationPage.java:139)
at net.sourceforge.ganttproject.gui.projectwizard.NewProjectWizardWindow.addWeekendConfigurationPage(NewProjectWizardWindow.java:52)
at net.sourceforge.ganttproject.gui.projectwizard.NewProjectWizard.createNewProject(NewProjectWizard.java:33)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.showNewProjectWizard(ProjectUIFacadeImpl.kt:266)
at net.sourceforge.ganttproject.gui.ProjectUIFacadeImpl.createProject(ProjectUIFacadeImpl.kt:261)
at net.sourceforge.ganttproject.GanttProject.newProject(GanttProject.java:703)
at net.sourceforge.ganttproject.action.project.NewProjectAction.actionPerformed(NewProjectAction.java:44)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.desktop/java.awt.Component.processMouseEvent(Unknown Source)
at java.desktop/javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.desktop/java.awt.Component.processEvent(Unknown Source)
at java.desktop/java.awt.Container.processEvent(Unknown Source)
at java.desktop/java.awt.Component.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.Container.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.Component.dispatchEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.desktop/java.awt.Window.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
I have removed any found instance and files from former versions and reinstalled newest GP 3.0 on my Win10 and it dont start up either for me. Can anybody
help me
Could it be an error in Java 8 build/version 301?
After I have
- Uninstalled Gantproject.
- Removed any GanttProjectfile and folders from my personal user-folder at C:\USER…
- In registry search for GanttProject and deleted all i coud find
- Reinstaled GanttProject 3100
- Updated to GanttProject 3102
It seems to work for me
